Forums >> Revit Building >> Technical Support >> Make Adaptive' tool is not available
Wed, Feb 12, 2014 at 7:00:29 AM | Make Adaptive' tool is not available
designimpressions
Hi,
I am trying to change a reference point to an adaptive point in the Curtain Panel Pattern based tempalte but the 'Adaptive Component panel Make Adaptive' tool is not available when I select the Reference Point.
Does anyone know what the problem is please?
Thanks Peter
Edited on: Wed, Feb 12, 2014 at 2:06:01 PM
Wed, Feb 12, 2014 at 1:53:10 PM | Make Adaptive' tool is not available
designimpressions
'Make Adaptive' is not available in the: Metric Curtain Panel Pattern Based.rfa template. There are 'Adaptive Points' in the Metric Curtain Panel Pattern Based.rfa template; are they hardwired in to the template?  If I copy one it changes to a Reference Point.
'Make Adaptive' is also not available in the: Metric Mass.rfa template; it is available in the: Metric Generic Model Adaptive.rft. Where is the Metric Generic Model Adaptive.rft? I cannot find it in the Family Templates library or the Conceptual Mass folder?
Thanks,
Peter
Adaptive component documentation
Wed, May 11, 2011 at 3:51:41 AM
Problem with a rectangular section on a adaptive arch
Sun, May 19, 2013 at 2:05:22 AM
adaptive components
Fri, Jan 23, 2015 at 7:12:31 AM
Problem with a rectangular section on an adaptive arch
Tue, Jul 16, 2013 at 7:21:17 PM
Adaptive component multi-profile sweep (R13)
Thu, Sep 25, 2014 at 2:03:25 AM
Page generation time: 9.6204
