22 Users Online (20 Members):
Forums >> Revit Structure >> Technical Support >> Arch Walls Block View of Struct Posts
I'm taking a RVT file from an architect and adding beams/posts to it. However, when I add posts inside the architects walls they disappear due to the walls blocking their appearance. If I hide the walls I can see the structural items I added inside them. It doesn't matter if the architects file is linked, or linked-then-exploded, the walls always block site of the structural items. Does anyone know how to allow the posts appear inside the walls??? Thanks!
"It doesn't matter if the architects file is linked, or linked-then-exploded" You can't explode a revit project so whatever you are linking in and exploding is not a revit project.
Sorry not "explode". I meant to say "ungroup".....
Not ungroup either. The file should just be linked.
Maybe this is part of your problem. You need your own file with the architect's file linked into it. You can then control the visibility of the architect's model seperate from yours.
It's a new file with the architectural file linked into it.
So in a view goto VG/Linked Revit/set it to custom/then VG/Model and set the walls as you wish. Maybe transparent, maybe coarse.... This is all up to you.
To review for clarity:
I create a new file. I link the architectural file into it. If my view is on "structural" I won't be able to see the architect's walls, so I change it to "coordination" view. Now the walls appear. I add a column into the wall and it disappears after being placed. I then hide the wall and the column is visible, which proves that the column is visible in that view range. How do I make this column visible in the wall? Thanks.
OK it's working now. Thanks for your answers.
We have >2K cols in proj. How can we replace our arch. elements 4 struct. ones |
Mon, Dec 12, 2011 at 4:05:12 AM
Combinng sheets from Revit Arch, Struct and MEP into one CD set |
Mon, Apr 13, 2009 at 2:40:35 PM
Structural walls in Architectural Model |
Fri, Aug 6, 2010 at 9:51:37 AM
Linking Arch file into Struct and using Arch groups? |
Tue, Jan 18, 2011 at 7:44:19 AM
Problems Copying Walls from Linked Arch Plans? |
Wed, Jul 15, 2009 at 4:23:32 PM
