Forums >> General Discussion >> Revit Project Management >> Curtain Wall Glass
Mon, Feb 10, 2014 at 11:11:39 AM | Curtain Wall Glass
stevedcnr
I am working with a curtain wall and am having trouble showing that the glazing is clear.
I click on the section of the curtain wall that defines each section and this is shown as System Panel  - Glazed. The properties material is Glass. Under materials the Glass Parameter is set at Clear with a reflectance of 15.
What is the correct way to do this?
Mon, Feb 10, 2014 at 11:15:06 AM | Curtain Wall Glass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What is wrong with the settings you have?
Mon, Feb 10, 2014 at 11:24:05 AM | Curtain Wall Glass
stevedcnr
The glazing is not showing as clear in any views.
Mon, Feb 10, 2014 at 12:18:06 PM | Curtain Wall Glass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
How is it showing?  What are you using as your visual style?  Do you have your material set to "Use Render Appearance" under the graphics tab in the Material Browser?  If not is there a color applied for the surface pattern?
Mon, Feb 10, 2014 at 1:27:25 PM | Curtain Wall Glass
stevedcnr
Under Manage > Materials > Glass > Graphics > Shading > Use Render Appearance for Shading > Box is Checked
Mon, Feb 10, 2014 at 1:56:25 PM | Curtain Wall Glass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I can't tell you because your not giving me enought information, communication is key.  I asked you.... How is it showing?  What are you using as your visual style? And you didn't answer either.  Attach an image of your material settings and elevation that is not working how you want
Mon, Feb 10, 2014 at 2:33:29 PM | Curtain Wall Glass
stevedcnr
Sorry about that.
The glass system panel appears to be opaque.
Visual Style is currently set at Hidden.
Attached is an elevation of the curtain wall.
Mon, Feb 10, 2014 at 3:17:11 PM | Curtain Wall Glass
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Are you sure you are just not seeing a wall behind the windows because in hidden it would just show up as white like it shows.  Are you using phases in your project? If so are your windows on the correct phase?  Do you have the transparency of the material set to 100%?
Mon, Feb 10, 2014 at 3:27:38 PM | Curtain Wall Glass
In hidden line views, material transparency doesn't work.  Select one glass panel, right click and select all instances in view and set the transparency there.
Mon, Feb 10, 2014 at 4:01:11 PM | Curtain Wall Glass
stevedcnr
Did it just as you said and it worked!! Awesome. Thanks You for hanging in there to help me with that.
Curtain wall: Change the glass colour?
Fri, Aug 27, 2010 at 10:13:57 AM
Curtain Wall - Glass and Mullion Detail
Tue, Oct 2, 2007 at 4:19:30 PM
Changing different glass types in one curtain wall
Tue, Feb 27, 2018 at 8:36:53 AM
How to place Curtain/Glass Door for Curtain Wall for Revit Architecture 2012
Thu, Jul 7, 2011 at 4:27:10 PM
External Glass Curtain Panel Problem
Tue, Aug 12, 2014 at 8:05:34 AM
Page generation time: 0.9105
