11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Window Head / Opening Cut
1 Posts No Rating |
I am wondering if it is possible to have a partial opening cut in a window family along with the full window opening. I have a window which I have created and I would like to recess the exterior head material partially into the wall, but because it is a concave shape, I need to remove the exterior finish of the wall in the area where the header occurs, and was wondering if that was possible.
To do this, you have to delete the opening cut and add your own void cuts. Be careful - create your cuts first because they will cut your objects if added afterwards.
head height of window |
Thu, Nov 3, 2005 at 5:19:14 PM
Actual Window Head height |
Thu, Jun 7, 2007 at 5:44:29 PM
Window head & Jamb [ 1 2 ] |
Thu, Jun 22, 2017 at 10:32:58 AM
20
window head showing in floor plan [ 1 2 ] |
Fri, Apr 29, 2011 at 1:51:22 PM
16
Setting Window Head Height |
Fri, Feb 24, 2017 at 12:16:49 AM
14
