11 Users Online (9 Members):
Forums >> Revit Building >> Technical Support >> Titleblock resized after export
I have a project with multiple sheets, and I have been exporting them as images. 3 of my 4 sheets print well, with my titleblock included, but on one of my sheets, the titleblock always ends up wrong. On this sheet, after eporting the sheet as a Tiff, like all the others, the titleblock shinks by 50% horzontaly, giving me a titleblock that is really thin, and out of proportion. This resizing leaves a large black spot where the titleblock should be. The titleblock on this sheet was made the same way as the others, just a blank 24x36 sheet with the image of the titleblock imported in.
I have put my A2 titleblock (the one that doesnt export right) onto another sheet, and it has worked. I guess this means it isnt a problem with the titleblock file, and it must be related to the GV settings or somthing.
Edited on: Thu, Feb 6, 2014 at 5:36:44 PM
I see no reason for this happening but I have seen corrupted sheets. Make a new sheet and move all your views to that. Does it work now?
Weird, I just switched my A2 titleblock (the one that was being weird on the sheet) to an A3 titleblock (which I have already done before, with no luck) but this time it worked, and the A3 titleblock was fine. when I put the A2 back on it worked fine. Im not sure why its working now, but it is.
Revit 2012 Export To DWG. Titleblock exported as Block. |
Wed, Jun 12, 2013 at 6:16:23 PM
Titleblock issues |
Fri, Nov 6, 2009 at 1:02:16 PM
Getting Titleblock in centre of page |
Tue, Mar 30, 2010 at 7:13:05 AM
Titleblock question |
Thu, Jul 2, 2009 at 4:23:14 PM
Titleblock Parameters |
Tue, Apr 19, 2005 at 11:55:06 AM
