Forums >> Revit Building >> Technical Support >> Dimensioning Drafting????
Thu, Feb 6, 2014 at 1:47:39 PM | Dimensioning Drafting????
minsky
1 Stars: 1 Votes
REVIT Architecture 2013
I'm in a drafting view (yea, I know now one uses it)  trying to complete a technical drawing.  For some reason I can't figure out, I now cannot dimension between circles.  See attached image.
top of image, completed earlier, I was able to denote "5/16" for that particular circle, and "3/32" for the distance between edges without a problem (or so I thought).
Now, below, I cannot denote "1/4" for the circle there (I put in fragments of lines in order to dimension it).  It simply will not let me do it.   AND, the killer is, in the aforeto mentioned above, if I delete the dimension, I cannot replace it, and if I delete the circle, the dimension disappears.
Again, this is a drafting view.  Did I turn something on that I'm not aware of???
Thu, Feb 6, 2014 at 2:09:27 PM | Dimensioning Drafting????
This is one of Revits problems... plus you can't dimension concentric circles.
Make your circle with two 1/2 circles.  Then you will have a point.
Thu, Feb 6, 2014 at 2:09:34 PM | Dimensioning Drafting????
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You can't dimension from one circle quadrant to the next, you can dimension from their centerlines.  Your dimensions must be from the threads and just dragged to look like it is going to the circle
Thu, Feb 6, 2014 at 2:42:45 PM | Dimensioning Drafting????
minsky
1 Stars: 1 Votes
Hmmm, well for some reason, like I said, I WAS able to do what I wanted above, but not below.  I have no idea why.
Dimensioning Drafting Views
Fri, Apr 3, 2009 at 9:03:24 AM
Dimensioning to the centerpoint of an arc
Tue, Jul 29, 2008 at 4:11:55 PM
A few questions
Wed, Jul 1, 2009 at 11:05:15 AM
Flagging new Drafting Views - How to reference a drafting view detail?
Wed, Aug 1, 2007 at 10:26:29 AM
Better Leaders For Dimensioning
Wed, Nov 24, 2010 at 7:52:57 AM
Page generation time: 0.0881
