Forums >> Revit Building >> Technical Support >> Interior Elevation not visible in drop down
Wed, Feb 5, 2014 at 11:41:37 AM | Interior Elevation not visible in drop down
Rams
3 Stars: 3 Votes
Interior elevation option is not visible in drop down menu. I know we can duplicate exterior elevation & rename it but I want to have system family so that it can snap to room edges.
This is problem with one project only as i can see interior elevation option in new project.
Using Revit 2013 as version
Now on the implementation stage....
Wed, Feb 5, 2014 at 12:12:07 PM | Interior Elevation not visible in drop down
2013 with all 3 updates - right?.... I doubt it.
Wed, Feb 5, 2014 at 3:55:54 PM | Interior Elevation not visible in drop down
Rams
3 Stars: 3 Votes
Yes 2013 with all 3 updates - see snapshot below:
Thu, Feb 6, 2014 at 7:34:03 AM | Interior Elevation not visible in drop down
Just create a new type under exterior elevation and call it interior.  Set the tag callout to what you use... round - square?
Thu, Feb 6, 2014 at 7:54:42 AM | Interior Elevation not visible in drop down
Rams
3 Stars: 3 Votes
I am already using that way. Unfortunately automatic room boundary snap is not possible then
Thanks,
Thu, Feb 6, 2014 at 8:05:32 AM | Interior Elevation not visible in drop down
Mine does.
The interior is in the commercial default template.
What did you do?  ... purge the original one because it was there.
Thu, Feb 6, 2014 at 9:19:32 AM | Interior Elevation not visible in drop down
Rams
3 Stars: 3 Votes
Thanks WWHub
I did Purge Unused & after that created Interior Elevation, however no luck. Please see snapshot below:
Interior Elevation Tag missing from drop down
Wed, Aug 18, 2010 at 4:28:45 AM
CAD import disappears in interior elevation
Fri, Dec 6, 2019 at 12:40:46 PM
Interior Elevation Option is not available
Tue, Jul 8, 2014 at 2:15:39 PM
View/ Interior Elevation Legend
Tue, May 12, 2009 at 12:58:01 AM
Elevation Markers: visible on all floors
Mon, Nov 7, 2011 at 12:24:27 PM
Page generation time: 0.3140
