Forums >> Revit Systems >> Technical Support >> can't align family
Wed, Feb 5, 2014 at 4:51:58 AM | can't align family
rafaelyn2
hello,
I'm trying to align a touch point in the Figure 1, but it automatically aligns the point of Figure 2.
can someone help me?
Wed, Feb 5, 2014 at 7:58:28 AM | can't align family
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What is it?  A wall?
Wed, Feb 5, 2014 at 9:40:01 AM | can't align family
rafaelyn2
beam and formwork
Wed, Feb 5, 2014 at 9:50:46 AM | can't align family
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
So the blue is an actual out of the box beam or a family you created
Wed, Feb 5, 2014 at 10:11:43 AM | can't align family
rafaelyn2
is a family line-based
Wed, Feb 5, 2014 at 10:17:45 AM | can't align family
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Instead of trying to align just drag it to where you want it if its line based
Wed, Feb 5, 2014 at 10:35:32 AM | can't align family
rafaelyn2
I try to drag but it automatically aligns the point of Figure 2. Can you try?
Wed, Mar 12, 2014 at 12:41:42 PM | can't align family
chilie
I don't speak spanish so I cant really fully follow the parameters you have set up, but I did look the family itself for the beam in question. I think the issue has to do with the family itself. For starters you are using a lot of reference lines. Some have strong references some are weak. In plan view, some of the lines dont seem to overlap the geometry itself. Reference lines aren't like Reference planes. If the line isn't over the geometry, then you cannot snap to it or align to it. I would suggest swapping all those reference lines for reference planes. You might have better results that way. The only time I use reference lines in my families is if the geometer is going to change angle at some point. The rest of the time, I only use reference planes.
Rotate 'n' Align Paintbucket Textures
Sun, Nov 18, 2012 at 6:39:30 AM
Align Floors on Multiple sheets
Wed, Nov 17, 2010 at 3:26:28 PM
align pipe to a revit family
Fri, Dec 17, 2010 at 10:13:08 AM
Align command in concrete curb family - Revit 2014
Wed, Apr 16, 2014 at 2:04:07 PM
Revit wont align siding
Fri, Dec 2, 2011 at 8:46:33 AM
Page generation time: 3.3584
