Forums >> Community >> The Studio >> what is the tool same as Marquee in ArchiCAD
Tue, Feb 21, 2006 at 11:00:03 PM | what is the tool same as Marquee in ArchiCAD
why8888
I am going to put the site plan into sheet, but i would like cut some of unnecessary part, how to do it Onho
Fri, Mar 3, 2006 at 3:32:29 AM | RE: what is the tool same as Marquee in ArchiCAD
eldados
eldados Avatar
4.5 Stars: 8 Votes
field region!
Integrator
KarelCAD
Sat, Mar 4, 2006 at 4:10:07 PM | RE: what is the tool same as Marquee in ArchiCAD
JAIMERIOSJR
You need to : 1. Right click on any blank side of the siteplan, and click on "View Properties"; 2. Scroll down loking for the "EXTENT" option, make sure that you check the crop section. this will create a box sourrounding the site plan. 3. Click on any part of the new box it will turn red with blue dots and section symbos; pick on the blue dots and adjust as required. When printing, this crop line will not show up I hope this is what you were looking for.
importing from archicad
Thu, Nov 27, 2008 at 10:55:38 PM
Find and Select tool
Wed, Sep 26, 2007 at 9:09:06 AM
Revit vs. Archicad
Fri, Sep 28, 2007 at 11:57:54 PM
14
Converting a Revit v 8.0 file into Archicad v10.0
Tue, Mar 24, 2009 at 4:21:51 PM
Wish it looks like ArchiCad
Fri, Nov 28, 2008 at 2:26:55 AM
Page generation time: 0.8479
