Forums >> Revit Building >> Technical Support >> Callout Detail
Fri, Jan 31, 2014 at 1:53:02 AM | Callout Detail
daait
I'm creating one callout detail of wall. i want to show same detail in two diffrent sheets it's possiable or not. plz help me.
Fri, Jan 31, 2014 at 6:55:51 AM | Callout Detail
JstoutDesigner
If I understand you correctly, you should be able to highlight your details and hit Ctrl+C then open your call-out then go to your Modify Tab --> Clipboard column --> Drop down Paste --> Aligned to Same Place.  I hope that is what you needed.
Fri, Jan 31, 2014 at 7:32:40 AM | Callout Detail
I think what you are wanting is a similar view.  Create a new callout but before you place it, check the "reference other view" chackbox on the options bar and pick the view you want referenced.
Detail callout vs. Floor plan callout
Mon, Nov 2, 2009 at 11:03:39 AM
Detail callout head size variable?
Wed, Mar 6, 2019 at 4:26:35 PM
Callout Detail Occurs @ Multiple Locations. Anyway to place detail bubbles...?
Thu, Jan 21, 2010 at 9:09:24 AM
How do I show a detail callout in more than one view?
Thu, Oct 7, 2010 at 1:22:09 PM
callout only head
Tue, Mar 26, 2013 at 7:09:20 AM
Page generation time: 4.7166
