Forums >> Revit Building >> Technical Support >> Multiple independent sheet index for cover sheet
Thu, Jan 30, 2014 at 3:40:48 PM | Multiple independent sheet index for cover sheet
Teffera
I am using Revit 2014 and I would like to create multiple sheet indexes- one for architecture, one for civil, one for mechanical etc...
I tried to start a new sheet list but it duplicates the original list which of course i can not edit. Any suggestions?
Thu, Jan 30, 2014 at 3:58:59 PM | Multiple independent sheet index for cover sheet
Sure - add a filter.  Are your sheets numbered with prefixes like A, S, E...?  Then just filter with sheet number starting with A.....etc.
If not, then add a sheet parameter that holds this information, add that to your schedule, filter it and hide that parameter in the schedule.
Edited on: Fri, Jan 31, 2014 at 7:14:26 AM
Thu, Jan 30, 2014 at 4:00:45 PM | Multiple independent sheet index for cover sheet
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
WWHub beat me to the answer
Edited on: Thu, Jan 30, 2014 at 4:01:16 PM
Tue, Feb 4, 2014 at 8:28:13 AM | Multiple independent sheet index for cover sheet
Teffera
Great! Thanks for the help.
Links to each sheet in sheet index
Sun, Aug 21, 2016 at 11:06:31 AM
sheet index..
Tue, Jun 17, 2014 at 9:10:40 AM
Cover Sheet
Wed, Aug 1, 2007 at 11:23:55 AM
Sheet / Drawing Index / List Check Box
Thu, Dec 18, 2008 at 8:48:15 AM
Cover Sheet Components
Wed, Aug 31, 2005 at 9:30:03 AM
Page generation time: 0.5692
