Forums >> Revit Structure >> Tips & Tricks >> void in family is yellow
Thu, Jan 30, 2014 at 8:54:38 AM | void in family is yellow
etrod1968
When i try to create a void family the void gets created but show up as yellow and doesn't cut anything
I am making a void for a wall.
What am i doing wrong why wont the void work?
Thu, Jan 30, 2014 at 9:18:30 AM | void in family is yellow
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
So you created a void family then loaded it into a project to cut a wall?
Once you created the void and inserted it into your project did you use the Cut Geometry tool? In the Family Category and PArameters did you check the box for Cut with Voids When Loaded?
Edited on: Thu, Jan 30, 2014 at 9:20:12 AM
Thu, Jan 30, 2014 at 12:06:07 PM | void in family is yellow
A void family?
In order for a void family to work, it needs to be hosted.  So your best process is to create it in a face based famil so that it works on any surface.  In the family, pick the void and set it to cut the host.
Sat, Apr 1, 2017 at 1:05:53 PM | void in family is yellow
fotio
Setting the family to ''cut the host'' is not enough, you need to, after having the family loaded, go to Modify tab/Geometry/Cut Geometry, select the host and the family so to have the desired cut effect.
Sat, Apr 1, 2017 at 2:23:17 PM | void in family is yellow
fotio,  there is no need to do what you say.  If the family is built to cut the host in the family, it will cut the host automatically in the project.
Mon, Mar 12, 2018 at 12:22:43 PM | void in family is yellow
sllana
5 Stars: 2 Votes
when you insert the family, you have to set the parameter (in the properties dialog) that defines the depth of your void (or whatever parameter you assign to the void) BEFORE you pick the intended possition, because it starts in 0.00.
nested void family
Wed, Jul 27, 2011 at 2:52:07 PM
Use Nested Void Family to Cut Host?
Sat, May 28, 2011 at 10:39:48 AM
Void extrusion family visibility
Fri, Apr 22, 2022 at 7:57:52 AM
Void Extrusion in window family problem
Mon, May 18, 2015 at 3:55:23 PM
weird yellow render RAC2009
Tue, Jan 6, 2009 at 2:29:31 PM
Page generation time: 2.2287
