Forums >> Revit Building >> Technical Support >> Creating open/closed furniture instances
Wed, Jan 29, 2014 at 7:18:59 AM | Creating open/closed furniture instances
EdArch
4 Stars: 4 Votes
Hi there,
I'm designing a couple of furniture ranges in Revit 2014.
I was wondering how I would go about creating instances with drawers/doors open and closed, so far I've had to
create separate families. I have a basic understanding of how to create instances, but not had any luck with this.
See the attached image for an example
Cheers
Wed, Jan 29, 2014 at 7:29:49 AM | Creating open/closed furniture instances
You can have two different solids in your family for your doors - one open, one closed - then you set visibility of those based on a new parameter that you create.
Wed, Jan 29, 2014 at 9:59:51 AM | Creating open/closed furniture instances
EdArch
4 Stars: 4 Votes
so for the drawers I'd just alternate the visibility settings? or would I be able to make a 'placement' parameter? or just simply create a new instance and move the elements?
Wed, Jan 29, 2014 at 10:07:06 AM | Creating open/closed furniture instances
The visibility setting can be a type based or instance based parameter.  The controlling parameter might be a T/F parameter like OPEN and the visibility setting can be an IF....
Search the forums for similar threads.  Also download the families guide from the autodesk site.
Stairs with Combined Open/Closed Treads
Sat, Jan 24, 2009 at 9:42:24 AM
Stairs - Ack! Half open, half closed
Tue, Jan 5, 2010 at 11:48:46 AM
Controlling Visiblilty Of Multiple Families
Wed, Oct 24, 2012 at 3:32:16 PM
Creation of a furniture model / linking problem
Thu, May 3, 2007 at 4:32:44 PM
Opening new files open new instances of Revit 2012
Fri, Sep 23, 2011 at 12:45:01 PM
Page generation time: 0.3460
