Forums >> Revit Building >> Technical Support >> Model text
Wed, Jan 29, 2014 at 6:27:36 AM | Model text
JoshSwear
Is it possible to have model text filled in? I creat it but it shows this "bubble text" with just bold letters that are outlined and white in the middle. Best I can do on my own so far is look at it in realistic colors and it infils gray. I need it to be black when shown on no color. Is this possible?
Wed, Jan 29, 2014 at 7:59:23 AM | Model text
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Did you happen to check your HELP or even the properties of you model text?  If you click on your text and look at the properties you can add a material the text.  And in the material you can change the surface pattern and color, in your case you want a solid black surface pattern
Wed, Jan 29, 2014 at 8:02:43 AM | Model text
JoshSwear
I did that, nothing changed. I even changed the surface pattern and still nothing. Is it something that would need to be printed to have it show up?
Wed, Jan 29, 2014 at 8:07:05 AM | Model text
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
No, you are not doing something right. Show me an image of you materials you assigned to your text
Wed, Jan 29, 2014 at 8:31:51 AM | Model text
JoshSwear
same as yours, I even tried the add a cut pattern as shown in the picture incase the view was cutting through it and nothing.
Wed, Jan 29, 2014 at 8:33:10 AM | Model text
JoshSwear
I found the issue. I need it to show up that color in a 2D floor plan view, not just in 3D. That is the issue.
Wed, Jan 29, 2014 at 8:39:57 AM | Model text
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
So you fixed the problem then?  There is still no issue from 3D to 2D it still works.  The image in the last post was a 3D and the one in this post is 2D.  Model text is 3D so it will show up everywhere.
Edited on: Wed, Jan 29, 2014 at 8:40:32 AM
Wed, Jan 29, 2014 at 8:45:48 AM | Model text
JoshSwear
Then no the issue isn't fixed. It shows up in 3D, not in 2D for me.
Wed, Jan 29, 2014 at 8:58:52 AM | Model text
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
What Revit version? Do you have all of the updates installed?  Can you attach an image of your material settings like I asked before?
Wed, Jan 29, 2014 at 9:03:27 AM | Model text
JoshSwear
nevermind I figured it out. I had multiple views named the same and one of the settings had it turned off. Thank you.
Wed, Jun 29, 2016 at 11:03:18 AM | Model text
iamian33
iamian33 Avatar
Hi.
I found this thread and am having the same issue, but I cannot find "...settings had it turned off" (these settings).  My model text shows fine in the family editor but not in the plan view of my building model.
I have the properties for the material set as noted above, but I cannot make the model text solid.  What am I missing?
Ian
Ian Shafer
Principal Consultant
True North S&F Consultants
missing text
Thu, Dec 19, 2019 at 3:35:19 PM
inaccurately displayed model text
Fri, May 11, 2012 at 3:39:20 AM
Self-Illuminated Model Text
Mon, Jul 28, 2008 at 5:56:01 AM
Text formatting (bullets & indents)
Wed, Jun 11, 2008 at 8:49:15 PM
RE: Model text positions
Mon, Dec 5, 2005 at 1:52:28 AM
Page generation time: 3.4634
