Forums >> Revit Building >> Technical Support >> Drawing lines on 3D topo
Tue, Feb 21, 2006 at 6:51:13 PM | Drawing lines on 3D topo
butlerc22
I created a 3D topo from an imported DWG and can't figgure out how to draw site elements (like a road or property lines) and have them lay on the 3d topo instead of floating above or below it in 3d view. Any ideas? Thanks!
Tue, Feb 21, 2006 at 10:35:14 PM | RE: Drawing lines on 3D topo
eldados
eldados Avatar
4.5 Stars: 8 Votes
to draw your property lines go to the site tab and pick the property line tool. regarding roads and sidewalks, you can do 2 ways: 1. split your topo and assign different material 2. more complicated but more accurate, refer tutorial on complex slabs... HTH
Integrator
KarelCAD
Tue, Feb 21, 2006 at 10:38:54 PM | RE: Drawing lines on 3D topo
butlerc22
Thanks for the reply, but the property lines you refer to (as far as I understand) only appear on the 2d plan view. I would like to show the property lines on the 3d view. Anyone ever do this? Thanks
Tue, Feb 21, 2006 at 10:41:47 PM | RE: Drawing lines on 3D topo
eldados
eldados Avatar
4.5 Stars: 8 Votes
the only way to show the property line in 3D is to model it, just make a wall (thickness to suite) and pick your property lines...
Integrator
KarelCAD
Sat, May 9, 2009 at 6:28:08 AM | Drawing lines on 3D topo
Tim130
I also imported a DWG into revet, this was to use the levels of the site and use the survey features which was contained in the DWG file. I have modeled the site and the trees onto my Revit topography, but would like to know how to 'bind' or 'attach' the dwg lines onto the Revit topo.
The DWG lines are shown to be floating about the topo in the image which I have attached.
Cheers
Tim
Sat, May 9, 2009 at 7:16:07 AM | Drawing lines on 3D topo
4 Stars: 205 Votes
Are your lines in the DWG in 3D??? you can control the level and the offset to position your lines but you CAN'T drapped the lines to the surface like CIVIL 3D does... I don't see any advantage to do that because the CAD file ONLY serve to guide you in your drawing, after that delete them...
Edited on: Sat, May 9, 2009 at 8:47:49 AM
Sat, May 9, 2009 at 8:07:15 AM | Drawing lines on 3D topo
tim123
4 Stars: 19 Votes
You can still use the CAD lines in the plan as information, but there should be no need for this in a 3d view.  You can use the lines as a guide to develop the 3d view as Typhoon suggests to create the different surfaces, such as roads and pavements.
Sat, May 9, 2009 at 8:43:44 AM | Drawing lines on 3D topo
Tim130
Thanks both,
I was interested in having the 2d lins which are from a AutoCad DWG be 'draped' over the 3d revit generated topo. However I understand this cannot be done, and I will continue to trace over the 2d lines onto the topo.
Thu, Sep 22, 2011 at 9:29:47 AM | Drawing lines on 3D topo
leeastwoodarch
For 3D Property lines, here is an imperfect workaround I normally use: create a subregion (or as many as necessary) by tracing your property lines, making sure you form a closed loop(s). Change the material so that your subject property "pops" out from the surroundings in shaded or shaded w edges views. you'll need to create several if you want to diffrentiate between interior and exterior roadworks etc. If you want to show several adjacent lots create several subregions with a small ofset from the property lines so that subregions don't share edges (but appear to). HTH
rsc at jalconsultants.com
Topo Lines part 2
Tue, Feb 28, 2012 at 10:05:01 PM
TOPO and Site Planning
Tue, Oct 30, 2007 at 7:10:48 AM
Revit 2017 - Topography contour lines visibility
Wed, May 5, 2021 at 1:55:53 PM
topo lines under trees
Wed, Mar 3, 2010 at 3:57:28 AM
Topo is struggling
Tue, Aug 15, 2006 at 9:24:01 AM
Page generation time: 1.5787
