Forums >> Revit Building >> Technical Support >> Spiral Stair I Need to start at 90 degrees and end at 90 degrees
Tue, Jan 28, 2014 at 1:20:22 PM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
romanosyr
I am creating a spiral stair and need to have the starting riser parallel to the end floor and the ending riser parallel to the top floor, the floors are stacked on top of each other (10'-0" fl to fl) it seems that there is no way for revit to automatically adjust the tread depth to make the start end end points parallel to the floors.  Has anyone found a solution to this problem?
Tue, Feb 18, 2014 at 1:04:20 PM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
mbsteve
mbsteve Avatar
4 Stars: 13 Votes
Did you review the first item in the similar threads below.
Tue, Feb 18, 2014 at 3:07:56 PM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
romanosyr
yeah I looked through the other posts didnt see a solution.  basically revit needs to be able to adjust the tread depth the way it adjusts the riser height in order to get the spiral stairs to stop and start at a specific location...add to wish list i guess
Tue, Feb 18, 2014 at 3:51:36 PM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
Mine are parallel.  If that's not what you mean then be more descriptive.
Tue, Feb 18, 2014 at 4:18:48 PM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
romanosyr
doesnt look parrallel...looks like the top tread/riser is at an angle
Wed, Feb 19, 2014 at 6:58:55 AM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Mine are parallel but I sketched mine.
Wed, Feb 19, 2014 at 7:24:04 AM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
romanosyr
Right and you can sketch it so long as you are not rotating 360 degrees but you cannot create a spiral that rotates 360 and ends with the starting riser parrallel to the final riser without being able to adjust the tread depth
Wed, Feb 19, 2014 at 7:32:39 AM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
Finally you tell us something, you want a full 360 degree stair.  That would have been beneficial from the beginning.  That begin 90 degrees and end 90 degrees has no bearing at all.
Just do your stair in two sections.
Wed, Feb 19, 2014 at 7:59:39 AM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I'm not seeing the problem?  Here is a 360 that starts at 90 and ends at do to eachother (rotated on screen a bit due to doing it fast).  This is done with stair by component.  Or as WWHub said do it in 2 sections.
Wed, Feb 19, 2014 at 8:37:24 AM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
romanosyr
maybe this image will help.
Wed, Feb 19, 2014 at 8:41:19 AM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
#11
romanosyr
well WWHUB it cant be done either way whether its 90 or 360 stair by component
Wed, Feb 19, 2014 at 8:56:57 AM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
#12
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I just did it with stair by component, 10' floor to floor height... I'm still not seeing why you are having a problem.  It can be done as I did it or as WWHub said in 2 pieces, you just need to watch your radius size.
Wed, Feb 19, 2014 at 9:11:36 AM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
#13
Prior to 2013, Revit never liked stairs that came back on themselves.  That is why once you stated the stair was 360, my answer still applies.
I don't do enough component stairs and I don't have time to check that out but if Tefoe says that also works then I'm sure it does.
Wed, Feb 19, 2014 at 11:16:50 AM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
#14
romanosyr
I see what you are saying tafoe.  If i needed a specific radius then its not possible without adjusting the tread depth
Wed, Feb 19, 2014 at 12:05:39 PM | Spiral Stair I Need to start at 90 degrees and end at 90 degrees
#15
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Correct
Spiral Stairs
Fri, Jul 4, 2008 at 1:34:57 AM
Spiral Stair
Wed, Aug 4, 2010 at 12:08:53 PM
Showing doors at 45 degrees
Thu, Apr 17, 2008 at 8:05:54 PM
Residential Spiral Stair
Mon, Feb 16, 2015 at 10:02:06 AM
Degrees symbol
Wed, Nov 23, 2005 at 12:33:00 AM
Page generation time: 0.4962
