17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> roof cut lines
12 Posts No Rating |
How do I make them go away? Can't find them in visibility graphics overrides and linework does't effect them
What roof cut lines? Cut from the cut plane of the actual view? or from an opening?
Adjust the cut plane if so.
the cut lines are roof openings in a house with 2 optional entries. the openings will not go into option sets so end up with lines in second option where I had to cut for the first the first option
So is the opening in the option set and the roof not?
I didn't realise openings would not go into options, sounds odd?
Temp fix would be a filled region in the view...
or use a generic model opening as opposed to the opening tool in the option...
i THINK THE OPENIG WOULD CUT THE ROOF IN THE OPTION i PUT IT IN THE RIGHT WAY WOULD BE TO HAVE THE MAIN ROOF IN BOTH OPTIONS WITH A DIFFERENT CUT FOR EACH. nOT BACKING UP THAT FAR THIS TIME THANKS FOR THE CHEAT.
Extra Roof Lines in Section |
Thu, Jan 28, 2016 at 12:45:54 PM
Hide roof cut lines |
Mon, Jun 5, 2006 at 9:03:04 AM
Roof: just can't get it right! |
Mon, Apr 11, 2011 at 3:32:07 PM
Can't make a Two Cut - Square rafter cut on a roof |
Fri, Jan 14, 2011 at 6:20:30 PM
roof lines in floor plan view...i need them darker..how? |
Tue, May 5, 2009 at 3:21:01 AM
