Forums >> Revit Building >> Technical Support >> Dwg Site Import
Tue, Feb 21, 2006 at 4:46:51 PM | Dwg Site Import
COLLEDGE
Ive read loads of threads & responses & did the tutorial but still cant successfully import a DWG site plan. The electronic copy supplied is scaled to 1:200. When I scale it back to 1:1 the boundary imports at the correct millimetre dimensions but the contour points do not. It appears the scaling throws them out. Does the problem stem from the A'CAD DWG. Are their various formats that may affect what I am trying to do. Regards Steve
Tue, Feb 21, 2006 at 5:12:40 PM | RE: Dwg Site Import
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Hmm, Sounds as though this is a bit of a bug in Acad. Have you tried leaving it at 1:200 and then scaling in revit?
trying to import site topo.
Fri, Jan 18, 2008 at 12:04:22 PM
Import DWG problem with size
Mon, Dec 6, 2010 at 7:33:32 PM
Can't import dwg or dxf to RS2008
Wed, May 30, 2007 at 10:36:07 PM
DWG Site plan not importing correctly..
Wed, Apr 1, 2009 at 4:43:31 PM
dwg import bring to front
Fri, Jun 27, 2008 at 9:46:56 AM
Page generation time: 0.8493
