Forums >> Revit Building >> Technical Support >> Section Boxes in 3D views
Tue, Feb 21, 2006 at 4:30:36 PM | Section Boxes in 3D views
DHerbert
DHerbert Avatar
Is there a way to enter values for height, depth and width to a section box? I am trying to export 3D views of my model in Revit to a mechanical consultant to use in Autocad Building Systems. I sent them an uncropped 3D view and they asked for a 3D view for each floor in the building. Any suggestions? ~Daniel
Tue, Feb 21, 2006 at 5:08:47 PM | RE: Section Boxes in 3D views
Scott Davis
3.5 Stars: 3 Votes
Use a callout for each level in plan. Then make a 3D view and go to View>Orient>To Other View, and pick the callout you created for the first level. Repeat for the other levels. You may need to tweak the 3D section box slightly to get the right height.
3D Cameras and Section Boxes.
Sun, Aug 16, 2009 at 10:32:08 PM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Two section boxes
Sat, Jan 30, 2010 at 3:28:51 PM
scope boxes / far clip offset / view range
Wed, Nov 6, 2019 at 2:11:05 AM
ANIMMATE SECTION AND CROP BOXES
Mon, Jan 23, 2006 at 9:25:44 AM
Page generation time: 1.1062
