Forums >> Revit Building >> Technical Support >> Symbolic Lines in Family - Display in Project
Fri, Jan 24, 2014 at 12:41:05 PM | Symbolic Lines in Family - Display in Project
dpbittiker
I have a few plumbing fixture families with hidden symbolic lines drawn in plan to indicate required clearances. When I load the families in to a generic 'new project' the lines display correctly as hidden/dashed lines. The problem I'm having is when I load them into my specific project, the lines are solid. I can't get them to read as hidden. Here's what I've checked so far in the project:
Object Styles, Line Styles, shading modes. I don't see anything abnormal, and it's driving me nuts! The clearance lines in the attached image should be reading dashed. Anyone know what it might be? thanks in advance.
Fri, Jan 24, 2014 at 12:44:22 PM | Symbolic Lines in Family - Display in Project
dpbittiker
Solved: It was a graphic override in phasing.
Symbolic Lines of family won't show up in Project
Wed, Aug 29, 2012 at 10:40:41 AM
Symbolic Lines and Model Lines
Wed, Mar 22, 2006 at 12:52:17 PM
Symbolic Lines Variation in Family
Thu, Feb 15, 2007 at 1:33:21 PM
Symbolic lines
Tue, Dec 26, 2006 at 2:24:22 AM
Symbolic lines in elevation
Thu, Jan 10, 2008 at 7:12:53 PM
Page generation time: 2.5556
