Forums >> Revit Building >> Technical Support >> similar detail marks
Fri, Jan 24, 2014 at 11:04:06 AM | similar detail marks
rossdes
I have two stair sections that are identical. How can I reference the first stair section to the second set of stairs? This is a "SIM" situation.
rossdes
Fri, Jan 24, 2014 at 11:17:27 AM | similar detail marks
When you cut your second section, use the reference other view from the options tab and pick the first section from the dropdown.
Fri, Jan 24, 2014 at 1:04:45 PM | similar detail marks
rossdes
Not to be dense, but what options tab are you talking about? I've clicked everything I can think of and don't see it.
rossdes
Fri, Jan 24, 2014 at 1:18:01 PM | similar detail marks
This one.....the bar right blow all the icons is the options bar.
Fri, Jan 24, 2014 at 1:24:51 PM | similar detail marks
rossdes
I see the green bar, but the modify/views is greyed. The offset dimension pops up and disappears very quickly. Is there something that has to be checked to activate the bar?
rossdes
Fri, Jan 24, 2014 at 1:31:46 PM | similar detail marks
I try very hard to write my answers clearly and succinctly.  The least you can do is to read them completely.
I wrote:   "....When you cut your second section, use the ...."  I said nothing about view properties or modifying a view.
Fri, Jan 24, 2014 at 1:33:08 PM | similar detail marks
rossdes
Found it! That was actually easy! Thanks!
rossdes
Fri, Jan 24, 2014 at 1:37:20 PM | similar detail marks
We used to joke around here about the options bar .... nobody pays attention to it initially .... but it changes with every operation so PAY ATTENTION TO THE OPTIONS BAR!
Display of detail marks
Mon, Oct 15, 2007 at 12:24:58 PM
Section marks w/ SIM
Thu, Oct 8, 2015 at 8:03:54 AM
12
Break Marks
Fri, Nov 14, 2008 at 6:53:42 PM
Detail section marks appearing EVERYWHERE!!!! RAC 2008
Fri, Feb 8, 2008 at 1:01:06 PM
Plan Callouts: Detail View Vs. Floor Plan Views
Thu, Aug 29, 2013 at 11:52:53 AM
Page generation time: 0.5335
