Forums >> Revit Building >> Technical Support >> Revit 2013 - Egress Path as Model Line
Thu, Jan 23, 2014 at 4:59:09 PM | Revit 2013 - Egress Path as Model Line
wbroner
wbroner Avatar
If one uses some of the methods suggested by posts on various Revit sites and makes the egress path some sort of a model line with a shared "Length" reporting parameter (so that a Tag can be used), does this line then show up in all the views?  If so, what is the most efficient workflow to make it appear only on Life Safety plans?
Fri, Jan 24, 2014 at 7:22:57 AM | Revit 2013 - Egress Path as Model Line
There is a family here on the site that does that.  I would place it in a workset that is set to typically off in all views.
Egress Door Tag
Tue, Mar 12, 2013 at 3:29:32 PM
need help with ALERT! EGRESS PATH ON FIRE
Fri, Dec 19, 2014 at 8:58:13 AM
Problems with Custom Fence and Egress Lines
Tue, Feb 3, 2015 at 7:15:13 PM
Calculatiing Egres Path
Mon, Feb 25, 2008 at 4:34:56 PM
Exit Remoteness diagram in 2010
Thu, Aug 13, 2009 at 8:31:52 AM
Page generation time: 1.6571
