Forums >> Revit Building >> Technical Support >> Multiple units on sloping site
Tue, Feb 21, 2006 at 3:26:59 PM | Multiple units on sloping site
Steve1959
I am setting up for the first time a sloping site (8 mts fall ) to take 7 detatched Townhouses/Villas. Units will be on 3 different levels on the site. Could someone please advise me the best setup method so I will acheive the following:- 1. In plan view I wish to view & document the total development. Dont think I can acheive this if I set different levels for different units. 2. Some of the units are identical but on different levels. Would like to copy these rather than redraw if it is possible. Regards Steve
Tue, Feb 21, 2006 at 3:29:29 PM | RE: Multiple units on sloping site
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Document each of the buildings in separate files then link them into the site. This will enable you to easily adjust there levels etc and move buildings around on the site as you see fit. You can also copy the links around so you can have a few copies of the same building on the site. HTH.
Managing large projects in Revit? Site with multiple units/buildings.
Wed, Jan 9, 2008 at 7:53:31 PM
Multiple Units
Fri, Jul 18, 2008 at 4:11:19 PM
Revit 2013 - Sloping site & retaining walls
Fri, Apr 19, 2013 at 2:55:40 PM
Site Problem
Thu, Mar 2, 2006 at 6:05:07 PM
How can I create calculated sloping ductwork, with elbows?
Sun, Feb 18, 2018 at 3:12:08 AM
Page generation time: 2.6914
