Forums >> Revit Building >> Technical Support >> Mirror Project - Revit Architecture 2013
Thu, Jan 23, 2014 at 12:35:19 PM | Mirror Project - Revit Architecture 2013
ROBPRDS
Hi! I am working on a project that needs to be mirrored. For example a two story home that needs to go from garage left to garage right. I go into the mirror project tool and the program locks up at about 29%. I tried letting it run over night and it still hangs at 29%. I tried purging the project, I tried omitting the site, I made sure nothing is pinned, I even copied the originak project into a new project file and nothing seems to work. Can anyone offer tips or ideas how to get the mirror project tool to work?
Thanks!
Rob
Thu, Jan 23, 2014 at 2:27:31 PM | Mirror Project - Revit Architecture 2013
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Do you have all of the updates installed for 2013?
Thu, Jan 23, 2014 at 3:35:33 PM | Mirror Project - Revit Architecture 2013
ROBPRDS
Hi! Yes- I have service pack #3 installed. I tried it on two computers too with the same result. Any thoughts?
Thanks!
Rob
Thu, Jan 23, 2014 at 3:46:57 PM | Mirror Project - Revit Architecture 2013
Do you have linked elements in this file?
Do you have inserted CAD in this file?  (Watch out for familiy inserts!)
Do you have images in this file - including decals?
Edited on: Thu, Jan 23, 2014 at 3:47:58 PM
Fri, Jan 24, 2014 at 9:55:23 AM | Mirror Project - Revit Architecture 2013
ROBPRDS
Hi,
I went through and un linked everythign and un pinned everything.
No decals or images in the drawing (I do have images in the title blocks)
No AutoCAD files in this one.
I did a save as for the past two or three homes to save some of the items that are specific to this project, can that have something ot do with this? Is it possible to purge out the "saved as" data?
Thanks,
Rob
Fri, Jan 24, 2014 at 10:47:20 AM | Mirror Project - Revit Architecture 2013
Save as has no affect and there is nothing to purge from that process.
We only used 2013 on one project because it was a poor release but that project was too large to test.   I upgraded a smaller project and I used the "mirror project" and it worked just fine.  <<< You did use the mirror project command from the Project Location/position dropdown?
Maybe you need to send the file to Autodesk.
Fri, Jan 24, 2014 at 11:47:37 AM | Mirror Project - Revit Architecture 2013
ROBPRDS
This the first time I am having trouble with the mirror project command. I have used is several times in the past and it worked great. I am using the mirror project from the manage pull down under position. What address would you use to mail the file to Autodesk? I never sent a file to them before.
Thanks,
Rob
Fri, Jan 24, 2014 at 12:32:11 PM | Mirror Project - Revit Architecture 2013
We are on subscription and this is part of that service.  You log in and create a ticket on your problem  They give you a download address and the turnaround is like 1 day.
Sat, Jan 25, 2014 at 5:41:31 AM | Mirror Project - Revit Architecture 2013
ROBPRDS
OK- I do not have subscription here.. Any other ideas on what I can try to mirror this plan?
Thanks for your help.
Rob
Upgrading Revit 2010 project to Revit 2013
Wed, May 23, 2012 at 1:28:20 PM
Mirror reflection always looks too distorted in renderings
Tue, Jan 27, 2009 at 4:15:43 PM
Modeling a bathroom Mirror?
Mon, Jan 9, 2023 at 7:28:43 AM
Civil Construction Drawings in Revit Architecture 2013
Sun, Jan 31, 2016 at 2:37:03 AM
Mirror Project...
Fri, Oct 17, 2008 at 3:30:14 AM
Page generation time: 1.7888
