Forums >> Revit Building >> Technical Support >> Exporting Floorplans as Images
Thu, Jan 23, 2014 at 8:22:10 AM | Exporting Floorplans as Images
Hythacg
I exported a 22x34 sheet from my project as an image, and when I open it in photoshop, it gives me the correct porportion but 300x the size size I indicated, giving me an image that is 6600x10200 with a resolution of 1 pixel per inch. I know I could just scale it down, and increase the resolution, but I'm not sure why it would export this big, if it is a 22x34 sheet.
Thu, Jan 23, 2014 at 8:53:39 AM | Exporting Floorplans as Images
For exports, you either select fit to in pixals (not sheet size) or actual size and you set the image quality.  What did you set it to and did you set it to lossless?
Camera views export blank images
Mon, Dec 9, 2013 at 2:13:16 PM
Exporting REVIT 8 Model to Photoshop7
Wed, May 18, 2005 at 11:50:04 PM
Exporting Sheets as image for printing.
Fri, Oct 14, 2011 at 6:13:23 AM
Error in the number of images in the Gallery...
Wed, Jul 16, 2008 at 4:43:03 PM
big floorplans - small sheets
Wed, Aug 23, 2006 at 9:15:28 AM
Page generation time: 0.1125
