Forums >> General Discussion >> Revit Project Management >> worksets vs linked revit files
Thu, Jan 23, 2014 at 7:26:56 AM | worksets vs linked revit files
deewash3117
3.5 Stars: 3 Votes
  1. Not sure if I'm posting this in the right location but my question is how should I go about setting up this project using worksets or linked files. The project will have all disciplines but small. It's a fueling pumphouse with a control center. Im pretty much the only person in the office that has Revit experience and will be working with two other AUTOCAD guys thats new to revit. How should I start the project with an Arch temp or Mech temp being that I will need piping and mech equipment. If I use a Arch. temp I will have to load all of the piping and mech. fittings, and on this thread I read that you dont want to link files that are small and in house. so how will I go about this? I was the lone ranger in the office using revit and now the firm is looking to get a few more guys involved. Or should somthing this small be done by one guy like me.
Thu, Jan 23, 2014 at 7:36:02 AM | worksets vs linked revit files
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Well it really depends on how "small" small actually is.  What version of Revit are you using?  We run the Revit 2014 Suite and ALL of our projects start with out own office template file, we don't use the ootb one.  We have a few pieces of mech, struct, and elec. but we mainly load in what we need when we get to that point.  If it is as small as you say it is I would not link files and just make sure everyone has a firm graps on worksets and how they can be used to control visability.  Working with and teaching people new to Revit can be hard at time so you need to make sure you are watching what they are doing.  Good Luck!
Thu, Jan 23, 2014 at 7:48:01 AM | worksets vs linked revit files
deewash3117
3.5 Stars: 3 Votes
Thanks we are running Revit 2013. I'm also in the process of creating office templates and Standards. (Load families as needed, and use worksets.)
Thu, Jan 23, 2014 at 8:03:42 AM | worksets vs linked revit files
I suggest you set up seperate working views in the project for each discipline to work in.  What you decide to show in sheeted views will probably be different.
? regarding controlling visiblity within linked files according to Worksets
Fri, Jul 2, 2010 at 10:01:40 AM
Linked Files and Worksets - best practice question
Wed, Jun 30, 2010 at 10:06:33 AM
editing linked files without having them unlinked?
Fri, Dec 4, 2009 at 10:06:44 AM
Working on Large Files
Mon, Jul 9, 2012 at 4:11:10 PM
11
autocad linked files and refresh
Tue, Apr 7, 2009 at 2:12:36 PM
Page generation time: 5.4380
