Forums >> Revit Building >> Technical Support >> Side S.A. Grille
Tue, Jan 21, 2014 at 5:28:21 PM | Side S.A. Grille
slovenc0417
Revit 2014
I am having a frustrating time adding side tapped grille to a mian trunk line.
This is how I finally accomplised it, but is there an easier way?!
1. I drew a duct (16x6) 15" of the main line.  That is long enough for a beveled tap to generate.
2. I then place on vertical face the 16x6 side register to the end of the duct.
3. I then delete the duct I originally drew (the bevel remains).
4. I select the grille and click on the icon that allows me to draw duct from the register.  I do so, and run it to the bevel.
5. Since the new duct does not exactly line up with the bevel, I window the new duct and the grille and move it until it lines up with the bevel.
6.  At this point I add a balalncing damper in the middle of the short duct run.
PLEASE TELL ME THERE IS AN EASIER METHOD!
Flush Side Duct Mounted Grilles
Wed, Jan 5, 2011 at 7:38:40 AM
Spiral Grille needed
Tue, Apr 1, 2008 at 10:42:10 AM
Floor Register/Grille?
Thu, Jan 4, 2007 at 6:24:08 PM
HELP with air terminals
Tue, Feb 9, 2010 at 12:13:25 PM
Window grilles break down when new types are added.
Thu, Dec 13, 2012 at 3:35:50 AM
Page generation time: 1.4199
