Forums >> Revit Building >> Technical Support >> Capping a Duct
Tue, Jan 21, 2014 at 7:19:23 AM | Capping a Duct
slovenc0417
I followed a very clear tutorial on Youtube on how to cap a duct.  You can use the ribbon and select "cap open ends" or simply select the duct end and right click and select "cap open end".
However, in either case I get the message:
"Revit could not find a matching Cap in "Rectangular Duct: Mitered (w/ vanes) Elbows/Taps".  Check the routing preferences of..."
I selected the afformentioned "Rectangular Duct: Mitered (w/ vanes) Elbows/Taps", went to Edit Type, "Routing  Preferences", "Edit...", scrolled down to "Cap" and found it to say "None".  No kidding!  The pull down menu had no other choices other than "None".
Does this particular duct family not offer caps, or is there something I can change that will allow it to be capped?
Or, do I need to download another type of duct family?
All help is greatly appreciated.
Tue, Jan 21, 2014 at 7:34:43 AM | Capping a Duct
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You need to load the caps into your project.  Go to insert family>Ducts>Fittings>Caps
Tue, Jan 21, 2014 at 9:46:17 AM | Capping a Duct
slovenc0417
That did the trick... thanks!
Ridge Capping?
Fri, Jan 27, 2017 at 6:44:05 AM
Roof capping
Wed, Nov 23, 2011 at 3:41:02 PM
Ridge Capping
Thu, Apr 21, 2005 at 6:59:24 AM
Duct Fitting Issue
Tue, Apr 1, 2014 at 1:16:35 PM
Duct won't tap to oval duct.
Tue, Aug 22, 2017 at 12:38:49 AM
Page generation time: 2.5144
