Forums >> Revit Building >> Technical Support >> Area Schedules
Mon, Jan 20, 2014 at 7:25:36 PM | Area Schedules
GlobalDS
GlobalDS Avatar
4 Stars: 1 Votes
How do I create an area schedule item that is different from the level name?
Revit 2014
I want to have a line item on my schedule that reads Garage/Decks but I still want the level to show up as Garage.
I try changing the area plan title to Garage/Decks & then rename the level on the section back to Garage, but the
Schedule always picks up the level name instead of the Plan name.
Is there any way to do this?
www.globaldesignstudio.com
Be Inspired!
Tue, Jan 21, 2014 at 7:17:28 AM | Area Schedules
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Your schedule will always read the actual level.  When you are looking at a section/elevation you actually see Garage/Deck so that is what you will see in the schedule.  Thats almost like saying you want to change the schedule to show First Floor but actually have the level named Area 1 (or something like that), nobody would know what the schedule was referring too.  Could you just rename your level to say Garage?
Area Schedules and Area Schemes - Revit 2019
Tue, Apr 2, 2019 at 7:41:56 AM
Area Schedules showing Metric and Imperial
Thu, May 28, 2009 at 11:49:29 AM
Combining Room Schedules and Area Schedules into one Large Schedule
Thu, Jan 3, 2013 at 10:57:33 AM
area plans & schedules help
Thu, Oct 8, 2009 at 12:56:31 PM
2 different Area Schedules on same project
Fri, Aug 4, 2017 at 12:41:21 PM
Page generation time: 8.1259
