Forums >> General Discussion >> Revit Project Management >> Entering Text in section view not working
Mon, Jan 20, 2014 at 9:37:50 AM | Entering Text in section view not working
revituser24
revituser24 Avatar
3 Stars: 1 Votes
I tried to enter text in section view, but revit won't display the text and I get an error message.  What is going on?
Mon, Jan 20, 2014 at 9:40:44 AM | Entering Text in section view not working
Your process must be incorrect but you have not told us enough to help you very much.
Is text on?Telling us what the error message said would have been useful!!!
Mon, Jan 20, 2014 at 9:49:17 AM | Entering Text in section view not working
revituser24
revituser24 Avatar
3 Stars: 1 Votes
The error message says, "Text created not visible in section view.  You may want to check the active view, its parameters, and visbility settings. "
Mon, Jan 20, 2014 at 9:52:04 AM | Entering Text in section view not working
Well then, did you do that?
Check VG - Is text on?
If not that then did you check where your annotation clip range is?  VP - Annotation clip box.  Uncheck it and see what happens.
Text Referencing a View
Tue, Dec 16, 2008 at 10:15:01 PM
How do I make a section that will not reference a detail or make a view?
Tue, Nov 11, 2008 at 6:18:55 AM
turning section head text
Tue, Nov 22, 2005 at 9:42:00 AM
Aligning text a section head
Fri, Mar 2, 2007 at 1:17:11 PM
Section family without the section view?
Wed, Apr 8, 2015 at 2:00:34 AM
Page generation time: 5.5244
