13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Offset in Revit 2014 !!!!!
The Offset Tool (OF) not working on grids and levels... why ?
I install Update 1 & 2 but the proplem not solve.
this has never been an option omarx1989.
Select a level, right klick and choose create similar to ad a Level, don't use copy either
(when you do revit won't create a level in the projectbrowser so it'll be useless).
Gridlines can also be added with create simmilar command, you can also use copy or array to ad gridlines.
Thanks for reply, gebber .
I know the other ways to copy or moves the grids and levels
but the offset tool works on grids and levels in revit 2013.
why not working in 2014 ??
2014 should be more feature than 2013
I see you're right about being able to ofset grids in older versions.
I only have 12 & 13 installed so I don't know about 14 yet but I don't see why you'd like to use the offset command for the grids.
I rather use copy or array as I mentioned before.
I gues the why question should be asked @ Autodesk.
You are correct this does not work in 2014. You could send an email to Autodesk as gebber suggested. I personally have never offset levels or grid.
i asked autodesk,
see the comment in the bottom this page !!!!
http://help.autodesk.com/view/RVT/2014/ENU/?guid=GUID-7D416FFB-36A2-4B98-95D1-0A007DCD51CE
Possible to specify the starting offset object? |
Thu, Aug 29, 2013 at 1:47:59 PM
Louver offset- Revit 2012 |
Fri, Aug 10, 2012 at 12:50:38 PM
How to import sketchup models into revit 2014 |
Fri, Aug 5, 2016 at 9:29:15 AM
View Range Revit 2014 |
Fri, Feb 20, 2015 at 9:55:04 AM
Column Attachment Offset |
Wed, Dec 1, 2010 at 1:07:31 PM
