Forums >> Revit Building >> Technical Support >> Offset face of Mass = possible?
Fri, Jan 17, 2014 at 5:35:21 PM | Offset face of Mass = possible?
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
I have a mass made up of triangular faces making up an exterior skin. Each face has a division of nodes related to the overall triangular geometry. On the interior I'm trying to align ceiling planes along these divisions. The problem is that I need the form of the mass to have thickness relative to each face that join cleanly. Not possible with extruding the faces of the mass nor do picking walls produce a good result. Is there a way to offset the faces of the mass similar to creating a shell so that I can have clean intersections? Thanks.
Mon, Jan 20, 2014 at 1:58:07 PM | Offset face of Mass = possible?
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
Here's a dynamo solution I'm going to investigate:
http://autodeskvasari.com/forum/topics/offset-a-complex-surface
Tue, Jan 21, 2014 at 2:06:18 PM | Offset face of Mass = possible?
crwinchester
crwinchester Avatar
3.5 Stars: 6 Votes
A better solution via the indefatigable Zach Kron:
http://buildz.blogspot.com/2009/05/seamless-panels.html
Conceptual Mass and Objects by Face Workflow Problem
Wed, Sep 5, 2012 at 7:19:24 PM
Reverse the face of mass for roofing
Sun, Dec 14, 2014 at 12:21:36 AM
Mass, radial wall by face, opening(void) problem!
Mon, Nov 11, 2013 at 12:51:10 PM
wall by face not being cut by void in mass
Wed, Jul 17, 2013 at 3:33:06 PM
Roof by Face and Wall by face tools
Tue, Jan 28, 2014 at 6:31:03 AM
Page generation time: 0.2119
