Forums >> Revit Systems >> Tips & Tricks >> Creating Editable Labels
Wed, Jan 15, 2014 at 4:09:01 PM | Creating Editable Labels
emanno
I am trying to create an editable 'Dummy' wall label (to put in legends and such).  Basically, it doesn't need to be a smart label just something I can edit.  For the life of me, I can NOT seem to do this.
I go into the label and set the parameter (NUMBER) but once I accept it, I can not click to edit it (It's like it's 'read only').  What am I doing wrong???  I started the family as a Generic Annotation
Thanks for any help you guys can give!
Thu, Jan 16, 2014 at 7:45:42 AM | Creating Editable Labels
Thread Post Kudo! #2
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If you are using a generic annotation family you will create a lable>add a parameter (call is something like wall type), set the type of parameter as text, set it to be an instance parameter and then load it into your project. From there it should come in as a ? that you can change to a number/letter
Thu, Jan 16, 2014 at 9:49:08 AM | Creating Editable Labels
emanno
Thank you!  This worked perfect
Thu, Jan 16, 2014 at 9:54:54 AM | Creating Editable Labels
emanno
Any chance you also know how to make the text rotate with the tag?  Its a triangular wall tag (a dummy one for legends and such).
Thanks for your help
Thu, Jan 16, 2014 at 10:33:36 AM | Creating Editable Labels
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You could use visability parameters by TYPE.  So you would have an Up, Down, Left, Right parameter for example.
Fri, May 1, 2015 at 1:12:14 AM | Creating Editable Labels
anthonyfee
hi i am new on this forum i like this your conversation...
Mon, Aug 1, 2016 at 2:46:12 PM | Creating Editable Labels
jeshicurr
4.5 Stars: 2 Votes
OH MAN thank you for this, teafoe5! EXACTLY what I was looking for!
Tue, Sep 1, 2020 at 9:23:04 AM | teafoe5
edenbensal
Quoting teafoe5 from 2014-01-16 07:45:42
im trying to do what you explain but i didnt succeeded.
i create a new title block and now i want to create the simple text editable label
Tue, Sep 1, 2020 at 7:05:46 PM | Creating Editable Labels
This should help you:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2019/ENU/Revit-DocumentPresent/files/GUID-5641C187-D1CC-494F-B20D-E01C46489DE8-htm.html
making labels editable
Thu, Feb 12, 2009 at 1:12:46 PM
Cant make editable labels in a title block.
Fri, Aug 7, 2020 at 1:11:01 AM
Titleblock issues: Can't 'activate' the labels I created...
Mon, Jan 24, 2011 at 3:49:27 PM
Creating Labels for Family Objects
Wed, Nov 21, 2012 at 9:29:11 AM
Creating custom labels showing area in a titleblock.
Wed, Aug 7, 2013 at 10:40:49 AM
Page generation time: 0.4828
