Forums >> Revit Building >> Technical Support >> Elevation Tags not showing when I cut a Section View
Wed, Jan 15, 2014 at 6:56:07 AM | Elevation Tags not showing when I cut a Section View
JstoutDesigner
Staight to the point, I'm creating a template and when I cut a section my Elevation tags are not showing.  I can make new tags but I want my original elevaiton tags.  Its not hidden or turned off in VG settings, whats wrong?
Wed, Jan 15, 2014 at 7:34:33 AM | Elevation Tags not showing when I cut a Section View
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
This doesn't make sense. you cant show elevations in a section  See the image of how the Elevation Command is grayed out in a section
Thu, Jan 16, 2014 at 3:07:14 PM | Elevation Tags not showing when I cut a Section View
blue442
blue442 Avatar
Think JstoutDesigner meant the Level indicators.  I forgot what i had to do to get mine back, it hink it had to do with the range of the elevation box in plan view.
Thu, Jan 16, 2014 at 3:17:26 PM | Elevation Tags not showing when I cut a Section View
If the poster meant the level indicators, ...read the HELP:
Datum Extents and Visibility
Datum planes, such as those for levels, grids, and reference planes are not visible in all views. If the datum does not intersect a view’s plane (or does not intersect the plane in the correct way), then it will not be visible in that view.
Datum planes are modifiable. You can resize their extents so that they are visible in some views, but not others. You can also change datum extents in one view and then propagate that change to any desired parallel views in which the datum is visible.
You can also use scope boxes to control visibility of datum.
Mon, Oct 20, 2014 at 2:43:05 PM | Elevation Tags not showing when I cut a Section View
mrbinnc
Also check to make sure that the levels workset is turn on in the sections / elevations.
Elevation Tags in 3D View
Wed, Feb 4, 2009 at 10:56:48 AM
Hiding View Name in Elevation View Tags
Fri, Jan 21, 2011 at 6:47:39 PM
can't see elevation tags in one view
Tue, Aug 30, 2016 at 1:34:14 PM
When I cut a section or elevation in revit, it shows what's behind the cut plane
Fri, Dec 6, 2013 at 12:47:17 PM
viewports & section tags
Mon, Aug 8, 2005 at 10:20:31 AM
Page generation time: 2.2545
