14 Users Online (12 Members):
Forums >> Community >> Newbies >> moving the model
8 Posts No Rating |
What is the best way to move the entire model 84'-0" north?
Why? .... in relation to what?.... There may be better options.
8 Posts No Rating |
The architect moved the building 84' north. I have to move my structural model
There are several options here and it's too bad the architect actually moved his model.
Watch this video:
http://www.youtube.com/watch?v=BigvY4LT-RI
I have a similar issue where one of three buildings will be moved a few feet on the site. Masking regions and detail lines were created in the elevation and plan sheets based off the existing location of this particular building. I want to avoid recreating or moving each instance of a line or region to match the new location a few feet away. Would manipulation of the survey and project points be the best method of doing this?
Thanks,
Jordan
I have no really good answer for you.
Because you are talking about 2D elements in views, you don't actually want to move your model in your project. You want to move how it is referenced. If the project and its relationship to other models was set up using the project location, then maybe that will work. Sometimes you just have to move the other links in relation to your model but then your consulants will have to move your link in their model.
Electrical components moving when reloading arch model |
Mon, Jan 5, 2015 at 9:01:02 AM
Devices Moving IN Model |
Tue, Dec 6, 2011 at 1:47:25 PM
Changing Level Elevations without moving the Model? |
Tue, Sep 4, 2012 at 5:58:03 PM
Moving a linked Revit model |
Thu, Nov 21, 2013 at 3:57:59 PM
Moving project to align with Revit Structural File |
Mon, Apr 22, 2013 at 7:22:12 AM
