Forums >> Revit Building >> Technical Support >> Material adding to slope glazing
Sun, Jan 12, 2014 at 9:41:57 PM | Material adding to slope glazing
DAMAREVIT
anybody could help me, i would like to apply a different materials to my slope glazing skylights, i have two skylights and they need to be in didifferent shades of glass; in revit 2013, please help me... damar_hutchinson@hotmail.com
tthank you
Mon, Jan 13, 2014 at 1:27:55 AM | Material adding to slope glazing
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
When selecting the curtain wall panel, you go to the type prooperties and create a new type.
You can give this type a different material than the other panel, thus creating skylights in different colours.
Mon, Jan 13, 2014 at 5:45:26 AM | Material adding to slope glazing
DAMAREVIT
yea, thanks howvever remember i am working with the slope glazing which is a roof family
Mon, Jan 13, 2014 at 7:10:45 AM | Material adding to slope glazing
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
revit uses the curtain panels in sloped glazing.
When you change a roof type to sloped glazing, Revit creates a roof similar to a curtain wall.
Mon, Jan 13, 2014 at 7:27:19 AM | Material adding to slope glazing
DAMAREVIT
will check out all that, the material has to be changed in the objects styles, and that changes all the curtain walls to the same material, and thats what i dont want
Mon, Jan 13, 2014 at 8:00:21 AM | Material adding to slope glazing
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
"the material has to be changed in the objects styles"- Wrong
You need to click on the glazing and edit the type and duplicate it as KimTaurus told you to do.  You need to individually change the glazing panels.
Mon, Jan 13, 2014 at 8:00:58 AM | Material adding to slope glazing
KimTaurus
KimTaurus Avatar
5 Stars: 3 Votes
In object style you define a material by category. This means when an element is not assigned a specific material if will receive this "standard" material. When selecting a curtain panel, you can specify a material for that panel, and create several panels each with a different material. Same goes for mullions.
Mon, Jan 13, 2014 at 8:09:13 AM | Material adding to slope glazing
DAMAREVIT
thanks, will try it when i get back in office, i will let you guys know it it worked (y)
Mon, Jan 13, 2014 at 9:04:28 PM | Material adding to slope glazing
DAMAREVIT
Thanks guys, it did work (y).. never stop learning
Curtain system > glazing panel matherial
Mon, May 28, 2012 at 1:02:14 PM
Help Glazing casting shadows in sun studies
Wed, Dec 16, 2009 at 7:19:40 PM
Standing Seam Metal Roof help
Mon, Sep 28, 2009 at 8:54:17 AM
Glazing in roof
Wed, Oct 17, 2007 at 5:52:52 PM
Changing Glazing
Wed, Feb 24, 2016 at 9:09:18 AM
Page generation time: 0.4587
