19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Revit 2014 - floor transparency and the linework tool
3 Posts No Rating |
I am a landscape architect, using Revit 2014 for site work. I am working on my first project in Revit 2014 and have an issue when I make floors transparent (any percentage) that I can't use the linework tool to change the edges to a different linestyle. Does anyone have a fix for 0o show up.
Are you talking in a section view.. 3D view.. elevation?? Eitherway I am having no problem using the linework tool after a transparency is applied. Do you have all of the updates installed for 2014?
3 Posts No Rating |
I am refering to plan view.
Can you attach an image of what you are trying to do? You can use the override graphics to change the projection lines. When I do it I can't change a line to be invisible because with the transparency you are seeing the line below. You could override your floor lines to be inivsible (or white) and then go back and use linework to change them to whatever you want.
Edited on: Thu, Jan 9, 2014 at 10:37:26 AM
Here is a image of my settings for the image above.
Linework tool issue |
Mon, Sep 26, 2011 at 3:20:44 PM
How to delete linework created by underlay |
Tue, Jan 31, 2012 at 9:45:57 AM
Linework Tool (LW) |
Thu, Mar 11, 2010 at 4:34:30 PM
linework tool - showing through? |
Thu, Nov 16, 2006 at 4:20:55 PM
Structural floor transparency |
Wed, Jul 27, 2016 at 1:28:48 PM
