Forums >> General Discussion >> Wishlist >> View on sheet indicator
Wed, Jan 8, 2014 at 1:46:29 PM | View on sheet indicator
FWelliot
It would be nice to have the veiw name change color or tone when placed on sheet to more quickly identify which views are on sheets.  This would be a parameter that could be turned on and off by the user if the user does not wish so see the new format.
Wed, Jan 8, 2014 at 1:57:19 PM | View on sheet indicator
That could be useful.
Did you know you can sort your browser to show only views on sheets or views not on sheets?
We have a convention in our office.  If the view is a reference view not placed on sheets, then it goes in a working view folder.  If it is not to be deleted then that is added to the name.  Also, if the view name is not used as a view name on the sheet, then the name is in lower case.  For instance default elevations a,b,c,d ... and on the sheet the name might just be ELEVATION.  In this case, we like the user to change the name form a,bc... to something like "Room 101 east"
Wed, Jan 8, 2014 at 2:03:16 PM | View on sheet indicator
FWelliot
Yes, We do use subcatergories to help sort views and also the do not erase suffix.  I thought of this becuase I just created 60 elevations and have begun to put them on sheets and now to get them to order properly I have to go back and forth between the plan and sheet to try to put them in some symbalance of an order.  Thanks for your ideas!
DEFUALT side of the level indicator
Thu, Sep 1, 2016 at 2:01:12 PM
How do I get rid of these indicator lines around my slab?
Sun, Nov 28, 2010 at 2:10:35 AM
2019 snap indicator color
Mon, Jun 3, 2019 at 2:54:05 PM
Spot Elevation Bottom Indicator
Mon, Feb 9, 2009 at 2:13:49 PM
Snap Indicator Color
Tue, Oct 8, 2013 at 10:05:02 AM
Page generation time: 3.8256
