12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> cleanup horizontal mullion at corner mullions, again....
please help.. have a deadline tomorrow...
i've seen some posts about this but i havent seen an answer that works with a a 45 degree mullion at the inside and outside corners of a curtainwall
see the attached image. the horizontals dont join cleanly and it looks like crap. i added the corner mullion to only one of the edges of the wall so in order for the glass to look clean, it continues past the mullion
does that make any sense. i dont understand why corner mullions are so difficult. this isnt something new to the world of architecture, you'd think they'd fix this by now
thanks!
Go to a 3D view and set the join switch for the horizontals to be continuous rather than the verticals.
Edited on: Wed, Jan 8, 2014 at 9:36:58 AM
I'm using Revit 2013. is there some new switch that i dont know about in 2014? or are you talking about the system Join Condition Value? if so i tried that one and it didnt work
Look at the image attached.
not sure why that posted 3 times....that was the first thing i tried, still doesnt work
i have it set to Border and Horizontal Grid Continuous
attached is what it looks like now (i modified the mullion profile from the last image)
Do you have wall joins on? Post another image showing your mullion setting where I point to.
45 degree corner mullions are a problem. A solution may be to define the CW from the outside edge.
i'm not sure if this is what you are looking for. i can send you the file...
A small file with only this cw and everything else purged would help us see the problem.
Horiz mullions wont clean up because of angled corner mullion |
Wed, Oct 1, 2014 at 8:43:20 AM
connecting horizontal mullions around a corner mullion |
Thu, Nov 17, 2011 at 12:38:25 PM
Adding New Mullions to your Mullion Tab Options |
Wed, May 11, 2011 at 5:51:35 PM
Corner Mullions |
Fri, Dec 6, 2013 at 11:05:58 AM
Mullions at corner of curtain walls |
Thu, Jan 21, 2016 at 10:52:07 AM
