Forums >> Community >> The Studio >> Units and Dim settings
Tue, Jan 7, 2014 at 3:45:00 PM | Units and Dim settings
sblanck71
Greetings
I am work on the structural side of projects and was looking in the architectural model that was sent to our office.  Number one thing I noticed was units set to 1/32" instead of 1/256" per what I believe to be standard.  Second thing was a whole list of dimensions families set for rounding.  For instance one was called ariel 1/32" round to 1/8".  Does anyone know the reasoning behind this?  Am I in the wrong for being so rigid in my ways as to not change the settings and holding fast to 1/256" as gospel?
Tue, Jan 7, 2014 at 3:49:23 PM | Units and Dim settings
We model to 1/256" and our base dimension is that as well but there are often circumstances where you will end up with actual x/256" dimensions where they are inappropriate.  In most cases no building components are ever built to that tolerance so a rounded dimension in those locations are good practice.
Settings for stringer
Thu, Oct 3, 2013 at 10:33:32 AM
Diminsion under dim line
Fri, May 18, 2007 at 10:10:30 AM
3d dim
Mon, Jun 16, 2008 at 4:09:16 PM
Family matter
Wed, Mar 19, 2008 at 11:38:29 AM
Dim Light Setting for Rendering is Not Functional
Thu, Aug 2, 2018 at 1:20:06 AM
Page generation time: 1.5990
