Forums >> Revit Building >> Technical Support >> How to create an <invisible> dashed line?
Mon, Jan 6, 2014 at 11:44:42 PM | How to create an <invisible> dashed line?
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
HI All,
Revit OOTB comes with an <invisible> linetype.
Is it possible to create the same linetype but have it dashed?
Thanks in advance
Beau
Tue, Jan 7, 2014 at 7:28:48 AM | How to create an <invisible> dashed line?
Why?
I don't understand why you would ever want this.  The invisible line is invisible!
Tue, Jan 7, 2014 at 6:13:40 PM | How to create an <invisible> dashed line?
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Hey dubdub,
Thanks for your response.
I've been trying to create a door family that shows circulation requirements for disabled users.
Although I had the numerous circulation nested families linked in fine and had their visibility controlled, I was unable to lock them to the wall face. I keep getting constraints errors.
See
http://www.revitcity.com/forums.php?action=viewthread&thread_id=32045
http://forums.autodesk.com/t5/Revit-Architecture/Controlling-visibility-of-nested-families-in-familes-with/m-p/4734057
As no-one was able to answer my other forum queries, I have been forced down the route to use invisible lines.
The intent now is to hover over the family in my project, so the invisible linework appears but does not print. I was just wondering if the invisible lines could be dashed and not continuous.
thanks
Wed, Jan 8, 2014 at 7:57:41 AM | How to create an <invisible> dashed line?
This is probably a process problem.
Did you use a locked dimension from the wall face to the family or an align lock?
Hosted families can be a problem to build.  I always like to create a reference plane well away from the host wall then place my elements in relation to that.  Then I create a dimension from the wall face to that plane and change the dimension to what it needs to be to move the elements into the correct location.
Wed, Jan 8, 2014 at 5:27:58 PM | How to create an <invisible> dashed line?
Beaucoupnice
Beaucoupnice Avatar
3.5 Stars: 6 Votes
Thanks WWDub. It took a fresh look. But I was able to make it work with the use of reference lines clear from the door geometry.
All the best.
Invisible lines removed from Line Styels
Mon, Feb 21, 2011 at 12:10:18 PM
objects above - dashed line
Fri, Oct 21, 2005 at 4:43:04 PM
Dashed line
Thu, Apr 25, 2019 at 8:49:22 AM
Revit 2009: Invisible lines displaying as dashed lines
Sat, Nov 14, 2009 at 11:57:17 AM
11
void behind solid object as dashed line
Wed, Dec 5, 2007 at 8:01:33 AM
Page generation time: 1.9644
