Forums >> Revit Building >> Tips & Tricks >> Make your own SHORTCUTS
Fri, Jun 11, 2004 at 3:28:41 PM | Make your own SHORTCUTS
Mr GG
3.5 Stars: 9 Votes
Make your own SHORTCUTS Go to the folder there you have installed Revit(eg. Progam Files) And open the folder Program and find the file Keyboardshortcuts.txt Make a copy of it - just for safety. Open Keyboardshortcuts.txt in Notepad. eg. if you want to use the function-key F9 to open the menu for hide/isolate you have to change this line: ;"" menu:"view-hide/isolate" so it looks like this instead: F9 menu:"view-hide/isolate" Save the file Keyboardshortcuts.txt and start Revit! to use your new shortcuts
Fri, Jun 11, 2004 at 4:36:35 PM | RE: Make your own SHORTCUTS
hjacobs
admin
hjacobs Avatar
3.5 Stars: 18 Votes
MrGG, Thank you for your contributions to Revitcity, I noticed you've been writing some short tutorials in some of the gallery comments. If you are interested in writing some tutorials that we can place on the site in the "Tutorials" page, please see the paragraph at the bottom of this page: http://www.revitcity.com/tutorials.php thanks!
Hiroshi Jacobs
Fri, Jun 11, 2004 at 5:46:07 PM | RE: Make your own SHORTCUTS
Mr GG
3.5 Stars: 9 Votes
I suggest that you make a new Forum called Tutorials and makes it possible to upload images and .pdf-files to that Forum perhaps also .doc-files but they are not a 100% safe... The best tutorials I think is the ones made with Flash and with sound And the video tutorials but they are big, too many bytes? So make a new Forum - called Tutorials - and make it possible to upload images and .pdf-files That will be good and I think you will have so many more contributions - now it is only three!!! But in the gallery there is more than three because it is so much more easy just to upload an image and a little text or have the text in a .pdf-file. Otherwise, RevitCity is great!
Fri, Jun 11, 2004 at 6:07:53 PM | RE: Make your own SHORTCUTS
Mr GG
3.5 Stars: 9 Votes
Perhaps you can use the same technique as in the gallery for tutorials - and call it eg. THE TUTORIAL GALLERY - using thumbnails. The members can upload an image and write an text to the image. And not only one picture with text - perhaps you need to use 10 pictures with text for a tutorial. And perhaps you also must allow the author to make changes to the text and switch images because most tutorials are not correct in the first round. By making a tutorial gallery you have made it possible to make tutorials in a direct manner just like uploading an image to the gallery And you will have more contributions of tutorials Look you have got 150 gallery images now but just 3 tutorials and one of them is of your own hand. Making a tutorial gallery is just a little programming. And you already have all the ingrediences. And you have invented something good And Revitcity will be greater than great
Looking for a few handy keyboard shortcuts
Tue, Mar 4, 2008 at 10:31:01 AM
Some Keyboard shortcuts not working?
Tue, May 5, 2009 at 2:52:55 PM
Keyboard shortcuts
Thu, Jul 3, 2008 at 11:14:44 AM
Keyboard Shortcuts Fails to Save or Import
Mon, Jun 27, 2011 at 6:25:50 AM
Keyaboard Shortcuts - Export Yes - Import Fail - Save Fail
Sun, Jun 26, 2011 at 6:10:48 PM
Page generation time: 2.0868
