Forums >> Revit Systems >> Technical Support >> Shared parameter shows up in Multi Category Schedule But not in Conduit Run type
Mon, Jan 6, 2014 at 2:27:49 PM | Shared parameter shows up in Multi Category Schedule But not in Conduit Run type
revitricky
I have created a Shared Parameter Called "Conduit Run Mark". It works perfectly in Multi-Category Schedules but I really need it to show up on my "Conduit Run" Schedules. This will help our staff to quickly identify a conduit run on an iso view sheet that has this schedule inserted. I have inserted it correctly and have made sure to select a "Whole Run" before entering text to the field. The problem is I just get an empty field. Its like there is no relationship for some reason.I know I could use the comments portion  but I want to save that for other circumstances. I am using Revit 2014. I watched a video showing it being done but not sure which version they were using. Any help wold be great . Thanks
Multi-Category Schedule with Links
Wed, Aug 10, 2016 at 6:23:56 PM
Multi-category lenght & volume parameter
Tue, Sep 18, 2012 at 8:38:15 AM
Light and Ventilation Schedule
Thu, Dec 27, 2007 at 3:01:34 PM
Shared Parameter Over Constrained Planes
Thu, May 18, 2017 at 2:13:21 PM
Conduit Run with Fittings
Fri, Sep 2, 2016 at 12:45:43 PM
Page generation time: 2.1988
