Forums >> Revit Structure >> Technical Support >> Plan / Section question ???
Mon, Jan 6, 2014 at 2:00:04 PM | Plan / Section question ???
kathey1
If I delete a plan view and I have section associated with that view is there a way that I can still keep the sections within that view ?
Mon, Jan 6, 2014 at 2:08:46 PM | Plan / Section question ???
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If you delete a plan view how would you keep the section in that view? The view is deleted so therefore there is no place for the section.  If the section appears in another view it will not get deleted.
Mon, Jan 6, 2014 at 4:33:56 PM | Plan / Section question ???
kathey1
right ok lets say im in a plan view and i want to do a stair drawing and i need a part of the plan where the stairs are, do i duplicate a copy of the plan view or do i do a callout of that area ?
Edited on: Mon, Jan 6, 2014 at 4:34:40 PM
Mon, Jan 6, 2014 at 6:01:35 PM | Plan / Section question ???
TKennedy
4 Stars: 8 Votes
Deleting a plan view will not delete any of the section views. You won't see the section callouts if they aren't visible in any other plans, but you can still find the section views in the project browser.
Tue, Jan 7, 2014 at 7:26:29 AM | Plan / Section question ???
You can duplicate a plan, create a new plan or you can use a call-out - your choice.  I prefer the callout so that the bubble directs the user to the view.
Fri, Jan 10, 2014 at 3:07:51 AM | Plan / Section question ???
kathey1
I have a scenario; I’ve been told that it is good  practice to not have too many levels (the only levels you should use is your main floor levels) So what is the best practice to do when you have a staircore and you have a stair half landing between floor levels.
Should I:
1.        Duplicate a floor level and change its view depth ?
2.       Add a new level for that half landing ?
I hope you understand what I mean
Cheers
Fri, Jan 10, 2014 at 7:35:53 AM | Plan / Section question ???
We don't have a separate plan for the landing.  It is shown in our floor plan for the main level.  The mid landing is not a level and not a floor - it is part of the stair.
Fri, Jan 10, 2014 at 9:55:42 AM | Plan / Section question ???
kathey1
but the half landing still needs supporting with steel so i will have to show it somewhere on a drawing. So im guessing the best practice is to duplicate a level and amend its view depth ?
Fri, Jan 10, 2014 at 10:18:30 AM | Plan / Section question ???
In any plan view, you can add a PLAN REGION that allows you to control the VP in that area.  Read your HELP on plan regions.
Fri, Jan 10, 2014 at 1:31:42 PM | Plan / Section question ???
kathey1
Yea I've used plan regions a lot I'm just looking at what is the best practice. I used to use callouts for the half landings but I'm gonna start duplicating floor plans and with plan regions. Thanx
Section tag missing on plan but section still exists
Tue, Nov 22, 2016 at 2:58:15 PM
Cut Pattern in Plan vs Section
Tue, Aug 25, 2009 at 8:47:59 AM
Wall Section won't show in both plan and building section
Wed, Jan 29, 2014 at 6:52:25 AM
Section Line in Extends Beyond Plan (2009)
Sun, Sep 21, 2008 at 11:30:18 AM
plan detail callout in section
Fri, Mar 29, 2013 at 12:48:11 PM
13
Page generation time: 0.6501
