Forums >> Revit Building >> Technical Support >> Family Parameters for Triangle
Sun, Jan 5, 2014 at 9:17:01 AM | Family Parameters for Triangle
romanosyr
I want the 4" leg of the triangle to always remain 4" but i would like to flex the 1'-3" length.  No matter what I try the 4" leg tries to change size can what exactly do i need to do?
Sun, Jan 5, 2014 at 9:19:25 AM | Family Parameters for Triangle
romanosyr
image below
Mon, Jan 6, 2014 at 7:23:17 AM | Family Parameters for Triangle
Instead of using a dimension to the end of the line, try using a dimensioned reference plane.  BTW.... Always place reference planes before you add geometry.
blue triangle grips won't show on beam select -
Fri, Jul 9, 2010 at 8:54:46 PM
Cant edit family parameters?
Wed, Jul 15, 2009 at 1:36:26 AM
Glulam Family Parameters
Tue, Sep 24, 2013 at 9:16:34 AM
Revision Schedule with Delta symbol?
Mon, Dec 20, 2010 at 2:54:29 PM
Door family - how to delete unwanted parameters
Tue, Feb 7, 2006 at 3:25:01 AM
Page generation time: 2.7799
