Forums >> Revit Building >> Technical Support >> External Wooden framing family created in Revit 2014 through elevation profile
Thu, Jan 2, 2014 at 9:23:55 PM | External Wooden framing family created in Revit 2014 through elevation profile
naseem1982
Hi there,
Can some one provide solution... how to opload the family correctly into project as its asking for start and end point to place but i dont have these points to the family i hv created. I tried to place it though normal upload and bring profile from project browser to place in the project through side elevation. Each time while providing end point of the model it getting deviated specially wooden louvers.
I am uploading the frame structure here so some one can experiment with any rectangular building block and try to place it on its top to provide second roofing system.
I hope, i am able to convey my problem as its bit complex i guess.........
Thanks in advance....
Mohammad
Fri, Jan 3, 2014 at 7:43:53 AM | External Wooden framing family created in Revit 2014 through elevation profile
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You created this as a Structural Framing family, like a beam it needs a start and end point that you need to draw.  So in a floor plan or roof plan view just select where you want it to start at and end at and it will draw it in.
Thu, Jan 9, 2014 at 2:08:23 PM | External Wooden framing family created in Revit 2014 through elevation profile
naseem1982
thanks alot for your advice and solution........
Wood Framing Walls Extension; Locating and External framing
Fri, Jul 31, 2015 at 8:03:14 PM
Revit 2014 - Array within Profile Family
Fri, Aug 29, 2014 at 9:35:42 AM
Callout on a framing elevation
Mon, Oct 5, 2009 at 8:29:41 PM
Custom Structrual Framing Tags
Thu, Sep 11, 2008 at 3:49:22 PM
Metal deck roof profile
Fri, May 13, 2011 at 1:05:51 PM
Page generation time: 2.6153
