Forums >> Workflow & Implementation >> API & Third Party Apps >> Digital Red Lining
Tue, Dec 31, 2013 at 8:24:32 AM | Digital Red Lining
DanR
We are looking for a product that can help facilitate Digital Red Lining processes with our Revit Models.  We are specifically looking for something that can help us find and list every sheet affected by a single change.  For example, if I change a door in my Revit Model, I would like the software to find every sheet that displays that same door (i.e. plans, RCP, door schedule) so I can make sure all sheets are coordinated after a change.  This would be especially useful during addendum sets.  To your knowledge, is there a plugin that can do this?
Tue, Dec 31, 2013 at 8:30:49 AM | Digital Red Lining
Start by looking at the plugins available on the Autodesk website.
Tue, Dec 31, 2013 at 8:32:56 AM | Digital Red Lining
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
From what I know Autodesk Design Review .dwf files is your best option at this time.
Tue, Dec 31, 2013 at 8:43:00 AM | WWHub
DanR
Quoting WWHub from 2013-12-31 08:30:49
I have searched the Product Enhancements on Subscription Center as well as the Exchange Apps.  Mostly I am hoping someone who knows of such a product will see this thread and steer me in the right direction.
Tue, Dec 31, 2013 at 8:47:06 AM | teafoe5
DanR
Quoting teafoe5 from 2013-12-31 08:32:56
You can do some nice stuff with .dwf red lining, however I would like more integration with the Revit software.  Something with a more BIM savy approach that works with the actual data, not just importing the red lines as an overlay.
Tue, Dec 31, 2013 at 8:55:47 AM | Digital Red Lining
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
There is nothing like that out there at this time.  If you want something that will basically make the change as you are marking it up then why not just make the changes right in Revit?
Tue, Dec 31, 2013 at 9:23:51 AM | teafoe5
DanR
Quoting teafoe5 from 2013-12-31 08:55:47
The change would be made in Revit, but we would like to know every sheet that would be affected by moving one or more elements.  It seems like this is something that could be done within the API.  Using the previous example of moving a door.  I would like to select it and see a list of all sheets that display this door.  That way I know every sheet that would need to be clouded in my set before I even move the door.  I would think all you would need is something that scans all sheets and searches for the door by its Object ID. Seems pretty simple.  If this does not exist, and someone takes my idea and makes an app that does this, please just give me a copy of the app for free since you will make a fortune off of it.
Tue, Dec 31, 2013 at 9:25:28 AM | Digital Red Lining
Although you might be able to create an app that sorts through every view looking for an element ID, I don't think that would be a useful process.  Revit will make the change in all instances so no coordination problems with that.  The problem will be correcting added 2D elements that refine the model elements.  Those will be in a very few views and good users should be able to ferret those out.
Tue, Dec 31, 2013 at 5:44:07 PM | Digital Red Lining
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
Revit, can...sort of do this already.  Create a text type or keynote text that is all red.  Set a parameter to read the red-liner's initials. Have that user complete the redlining process.  Whether its through keynoting (or other) you should be able to create a schedule that transmits the information to the end user for the changes that HAVE and WILL be taking place.
So you won't be able to use it on schedule sheets, or legends (just anything that is a wall, window, etc...), but you will be able to use it on pretty much everything else.
I'll take a screenshot.  Sorry for the blurring.  Winking
-rbc
RB Cameron
3D Medical Equipment
Download Revit Healthcare Models Now
Download Other Revit + 3dsMax Models Here
Wed, Jan 1, 2014 at 12:54:44 PM | rbcameron2
DanR
Quoting rbcameron2 from 2013-12-31 17:44:07
-rbc
Not exactly what I am trying to do.  But that is pretty slick!
Thu, Jan 2, 2014 at 8:04:39 AM | Digital Red Lining
#11
DWF markup does this process much better and you can track who made the cahanges and when in the markup while withing Revit.
Watch this video http://www.youtube.com/watch?v=eoMT5zH1nlk
Edited on: Thu, Jan 2, 2014 at 9:17:14 AM
Mon, Jan 6, 2014 at 6:23:46 PM | Digital Red Lining
#12
rbcameron2
rbcameron2 Avatar
4 Stars: 25 Votes
WWHub is correct, there are better programs out there.  I was simply mentioning that you could track who made the changes by simply putting your initials after the note (also could include a date/timestamp).
However, you could also create a "start up page" in your Revit model that tracks these changes AND every time ANYONE opens the model it defaults to that "start up page" first, creating the ability to notify users of the tasks that
A) are completed
B) need to be completed
C) when they were issued and by who
D) gives them a list of things to do for the day
All locally within Revit...
This accomplishes another task... which is assignment of work to team members WITHOUT having to take another step to inform them.  also, everytime they open the file AND Person X can see what task Person Y is doing once they open the revit (collaboration) model.  Winking  Whoops, I left off the "Date stamp" on the schedule.  Cryingsee attached)
RB Cameron
Door Lining Depth
Thu, May 3, 2007 at 2:39:56 AM
Digital vs. Analog
Wed, Apr 30, 2008 at 12:41:33 AM
Can't Get Rid of Demolition Red
Wed, Jan 15, 2025 at 7:43:06 PM
Cant find ductwork lining settings and fitting settings.
Tue, Apr 7, 2009 at 10:44:56 AM
Advice on wall linings
Fri, Oct 27, 2017 at 2:04:59 AM
Page generation time: 1.5222
