Forums >> Revit Building >> Technical Support >> Some of all of the family files you selected cannot be loaded. You must........
Fri, Dec 27, 2013 at 12:56:06 PM | Some of all of the family files you selected cannot be loaded. You must........
MongooseST1
MongooseST1 Avatar
I am using REVIT 2014 Building Design Suite Premium. Under the STRUCTURE tab and in the MODEL tab I am endeavorign to upload into my drawing standard dimensional lumber shapes from the RVT 2014 folder under Structural Framing. When I do I get the followign error msg....Some of all of the family files you selected cannot be loaded. You must choose family files of the catgory component. Do you want to retry loading a new set of files?......
I assume when one loads a component it is a revit family or .RFA.....There is somethign I am doing wrong here and I cannot figure it out. I am usign the same procedue I have been doing on prior REVIT verisons with no problem....
Thanks in advance!
Fri, Dec 27, 2013 at 1:03:39 PM | Some of all of the family files you selected cannot be loaded. You must........
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
If you are getting that error it is because you are trying to load a family that is not the correct category.   Go to the insert tab>Load Families and try doing it from there and see if you still get the same error.
Inserting MC Channels as a compnent
Thu, Jan 19, 2012 at 5:35:48 PM
Download commponents from file
Tue, Nov 22, 2011 at 4:22:00 PM
Family loaded into project but is unable to place
Tue, Apr 19, 2011 at 9:57:26 AM
materials in family files
Tue, Sep 30, 2008 at 10:25:36 AM
I am having trouble loading the structural trusses
Thu, Oct 7, 2010 at 3:58:09 PM
Page generation time: 0.7159
