Forums >> Revit Building >> Technical Support >> Problem with the walls
Fri, Dec 27, 2013 at 11:47:21 AM | Problem with the walls
klausau
Hi everyone, I'm a begginer in revit and I have a question about walls. What causes the cut in the walls, which can be seen in attached picture? All the exterior walls of level 1 are cut and i would like them not to be so. How can i solve this problem?
Thanks. Smile
Fri, Dec 27, 2013 at 1:39:28 PM | Problem with the walls
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
You must have a reveal set in the wall structure.  If you edit the type, change the view to section view and you will be able to see what sweeps, reveals etc are added to the wall.  I don't suggest removing them as it will remove them from all walls of that type, you are better off making a new wall type or using a different one.
intersecting inner walls with slanting outer walls
Wed, Feb 27, 2013 at 7:51:10 AM
Demolished walls hiding proposed stuff
Tue, Sep 20, 2016 at 5:54:34 PM
Most Bizarre Revit Problem EVER
Thu, Jan 22, 2009 at 11:43:49 AM
Structural walls in Architectural Model
Fri, Aug 6, 2010 at 9:51:37 AM
Problem with underlay, cant see walls!
Wed, Jul 4, 2012 at 9:33:18 AM
Page generation time: 4.2719
