Forums >> Community >> Newbies >> Painting walls across phases
Thu, Dec 26, 2013 at 10:02:19 AM | Painting walls across phases
ryantcook
Working on a remodel project, phases have been utilized to show exisiting, demolition, and new construction phases. It appears that I am only able to paint walls/ masses that were built during the new construction phase. Is there anyway for me to paint exisiting walls without transferring them to the new construction phase? Thanks in advance
Thu, Dec 26, 2013 at 10:36:07 AM | Painting walls across phases
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
Paint can't have its own phase so if you paint an existing wall it is essential a new wall (or thats how Revit Sees it).
Thu, Dec 26, 2013 at 10:52:29 AM | Painting walls across phases
ryantcook
thanks but that does not answer my question. any other ideas? thank you
Thu, Dec 26, 2013 at 11:36:08 AM | Painting walls across phases
teafoe5
teafoe5 Avatar
4 Stars: 47 Votes
I don't know what your process is going to be so its hard to give you an exact answer. Wwhat is the point in painting your wall?  Are you going to schedule it?  You could create 2 walls one existing to be demo'd and one new right on top of it with your finishes and only schedule your paint on the new. You could also create a very thin new wall and place it next to the existing with your finish applied to it and join the existing and new walls.
Thu, Dec 26, 2013 at 12:36:57 PM | Painting walls across phases
ryantcook
That is a great idea. I am trying to create different color variations to show a client, I successfully moved all of the walls into the same phase. And am now using design options to have different color combinations. Thank you for your help teafoe5 !
Painting Single Walls
Wed, Oct 17, 2007 at 9:10:34 AM
painting walls
Mon, Feb 20, 2012 at 9:35:25 PM
painting walls
Tue, Jul 5, 2011 at 6:29:48 AM
Construction Phases
Mon, Jun 30, 2014 at 8:32:26 AM
How to show all new phases as new
Fri, Mar 7, 2014 at 11:59:09 AM
Page generation time: 0.6426
